Ok, I know someone has been through this...while removing my rear sway bar, two of the chassis/frame mounting studs broke off...they must have been very soft metal because I did put that much force on them to break them? One is an upper stud, the other is a lower...Both are blind studs welded in from within the chassis tube, the upper I believe can be drilled out all the way through the other side of the tube section and a long bolt could be pushed through? Any suggestions on fixing them?
Thanks for any help!
Tom Borcich
#4382
