I just purchased my '73 Pantera and the previous owner had the original 15x8 and 15x7 Campagnolo rims polished. I obtained copies of all the receipts ($13,000 in 5 months he spent (& the previous owner had it 22 years), my seller ran into some 'need for cash' had just purchased a $50,000 'crate' twin turbo motor for his 6 passenger Cessna he was restoring to aircraft specs, worth $350,000, when completed, an aircraft mechanic, and my Pantera was stored in an airport hanger at John Wayne Int'l Airport, his Cessna restoration project had some landing gear problems, landed on it's belly and he had an insurance salvage job with profit potential, and he was neck high into this investment, so it was down to the aluminum skin on his plane with new riveting happening, gotta respect that: knows all the aircraft spec parts vendors...)
Anyway, the wheels were polished, look like the 'Campy clones' you see advertized. But these original Campy's are magnesium, so they had to be clear coated, to avoid tarnishing again, he knew that, did it and was never intending to sell the '73L. The vendor is Al Reed Polishing, somewhere in So-Cal. Cost about $300 to do the polish & clear coat for all 4, total, but gotta add in mount, dismount, balance. He had all the receipts stapled together and when flipping them to make copies for me (had to keep the original receipts for tax purposes) he cut off the address, with a Visa sales ticket....
Also had new P195/50R15 put on front (lowers the front end, tire is about 2.5" pavement to outer rim) and P295/50R15 on the rear (raises the rear end, tire is about 5" pavement to outer rim)
This'll do for now for me, until next year, then I'm gonna budget for 16x8 front and 17x11 rear plus new skins!!!
Also got adjustable shocks, so front is further lowered and rear is raised, but not enough for me!!
If I didn't have adjustable shocks, I'd go with removal of the spacers on the front and keep the spacers on the rear Koni's. See
www.panteraplace.com and look for the topic addressing GTS Panteras. There you'll see Michael Murhy's GTS Pantera at a Pantera event in Vegas. That's my goal! No spoilers needed and when you really get into it and check the info from the factory wind tunnel testing done 30 years ago and see that the Factory Pantera has lift of 145 lbs in front and the rear has no lift at 150 mph, you'll see why I want to do this. No lift at 150 mph w/o a front spoiler when the stance is lowered in front and raised in back like Murphy's (note the level of the roofline contrasted to the roofline of stock Panteras, see also the levelness of the rocker panels measured at the lower door jam), and w/o scraping the front valance, like when you have a spoiler in front(expensive).
The Pantera doesn't need a rear spoiler b/c the air is pushing UP thru the grill behind the window and never even touches the rear wing at 150 mph (see speed test of Hall Pantera at Utah Bonneville Salt Flats). Rear wings are just for looks on Panteras.
It looks HOT. And that's why horns honk at me on the freeway, and when I look over and wave hello, they're flashing photos, and not just A photo, a WHOLE ROLL of film!! When are they ever gonna have a chance to see THAT again???
Makes ya feel like a MOVIE STAR!!!!
I RECOMMEND IT!!!!
