Will these work as REAR wheels with my 'normal' stock front wheels? Not sure of the width of my stock rear wheels, sorry, new to this.
So, I could use these (yours) as my rears, and put EITHER my current fronts or rears on the front, correct? Or is this just a bad idea all the way around?!
I did some quick measuring. The Campy 15 X 8 and the Clone 16 X 8 have almost identical offsets. So the Campy Clone would be just as well spaced as the original wheel. The original 15 X 8 with a 215 X 70 X VR15 tire combination looked pretty skinny under the Pantera and didn’t even come close to filling the wheel well. There are not very many performance tire options for 15 inch wheels these days. I think you would have a much better chance of finding a nice wide, low-profile tire for the 16 inch rim. Moving the 15 X 8 to the front is a common swap. I have 15 X 8 in front and 15 X 10 in the rear.
