The "big plastic things" look like the steering column cover. It's mounted right behind the steering wheel and covers the column. You will find the two halves fit together like a clamshell.  The round hole is for the ignition switch to protrude through, and the rectangular hole is where the turn signal switch stalk sticks through.  The large tabs on the back with holes line up with the mounting point for the steering column under the dash.
As for the shim, I'm not sure.
