1)given the differences in the layouts of the two carbs, how much rearranging of things will be needed?
2)any other parts needed for the conversion?
3)is the carb lower profile than the Motorcraft 4300? That would make fitting a phenolic spacer easier.
4)what driveability issues does the stock carb have?
1) Not much I think. The accelerator cable pulls from the front on Pantera, so you need some pivot thing attached to the lower part of the bracket, as it is today
2) Make sure to get the fuel lines. But if you have rubber today, there might be a fitting or two you need
3) Sorry don't know, anybody know? (IMHO the engine cover should be taken off and put in the attic until the "original" wave hits the Pantera community. I want to see my engine in the rear view mirror, why hide it?)
4) Well a perfectly tuned carb: None. But the design is not optimal so slight misadjustment gives bog. Actually that applies to most carbs, if you look at a co2 air/fuel ratio instrument, the engine is always lean just when you push the accelerator. All I know is that the Summit carbs I've owned and the one we put on Timster's Pantera, worked perfectly after 1 minute of adjusting as described in my book. I can't stand a car that bogs down, I want instant power, or I hate driving the car. That's why I don't like modern cars with electrical accelerators instead of cables, there's a slight hesitation, I hate it. Had a Audi A4 V6 and a Jeep Hemi, both company cars, with plenty of power for their size, both were dreadful to drive because of electrical accelerator
Picture of my Longchamp carb after 2 years of use (yes, laugh at my points distributor, after having tried two Mallory electronic dist/modules and got stranded, I'm back to points just now)
