2 references for Karmann Ghia strips from JC Whitney...
Cat Whiskers
Source: http://realbig.com/pipermail/detomaso/2008-October/101827.html
For the catwhisker at the belt on the outside of the sideglass you can use the Karmann Ghia replacement from JC Whitney for about $8.50 a pair.
You will probably have to drill some small holes to screw it on to the sheetmetal down-flange and shorten them slightly.
Cat whisker felt alternate
Source: http://realbig.com/pipermail/detomaso/2008-April/095111.html
If you ruin that little felt strip on the glass channel in the door do not buy new ones for $250 from any friendly Mangusta / Pantera "Supplier".
Go to JC Whitney, look in the Karmann Ghia restoration section, you can get a set for about $8.00.
Wilkinson also has the side and top glass run felt at $6.50 each (x 4 for both doors). He also sells the front felt for $11.50. All three are the same material and cross section, but the front has part of the "bottom" of the channel removed (near the top of the door) to clear an overlapping tab on the upper part of the door frame. You could just buy another one of the $6.50 pieces and cut out the bottom yourself.
