Here is my 2 cents that will create all types of hot replies. Back in the day when I was a defense engineer we ran into problems with chromed parts and hydrogen enbrittlement. The process of chrome plating would change the base metal and make it brittle. Parts would end up snapping. From that day forward, I avoided chrome plating any key structual part. I am sure the risk is low on a sway bar but is it worth any risk to have the thing snap unexpectly?
To learn more: http://www.corrosion-doctors.org/Forms/embrittlement.htm
RoverLTD, we'll face the heat together, because I agree with RoverLTD. Chrome plating is good for decorative parts, but not parts that will be stressed. I've even had problems with cad plating of stressed parts, causing welds to become brittle & crack.
The powder coating industry now has a powder that comes out of the oven looking like polished aluminum, can't beat it.
your "cracked" friend on the PIBB, George
Anyone try plating themselfs? I got some stuff to do Zinc, Hard chrome, and nickle. I have not had a chance to try it yet although I have used the Eastwoods Zinc on a few things.
I am refurbashing an english wheel. When I clean up the wheels I was thinkng of plating them either hard chrome or nickle. Which would be better?
Gary
Hydrogen embrittlement is an issue with chrome plating and other plating as well. There are provisions to address the problem, one is the process/procedure during the plating, another is post baking after plating. Both are established and excepted as reliable corrective actions. Unfortunately decorative and automotive platers do not know what hydrogen embrittlement even means but industrial/military grade plating houses are familiar the processes.
I did my own post baking of Pantera suspension parts and fasteners to insure proper strength.
A good automotive plater will know what Hidrogen embrittlement is, I have been dealing with it for some time on automotive parts. As a general rule do not plate structural parts that are hardened past HRC 39. H.E. will mainly occure on samples in tension and the hydrogen that is trapped in the plating process will migrate to the grain boundries of the steel in the tensilly loaded areas, making them brittle. Post baking is done to cook out the hydrogen. The thicker the plating, the higher the hardness, the longer the bake.
