Originally posted by 22 Racer:
Thanks for all the input. I'm assuming the dieseling when turning off ignition must be a compression ratio-octane issue. When running race fuel, the car did not diesel at all, only after running premium pump gas (with no race fuel) did the car start dieseling. Before I used pump gas, I was told it may diesel without race fuel due to the closed chamber heads. We were concerned the compression was too high for pump gas and it appears to have turned out this way. The car runs so strong with these closed chamber heads, I really prefer to keep them if I can come up with a solution other than resorting to race fuel. Thanks again
It all isn't this simple. First you need to determine if you have an excessive compression ratio engine. Anything over about 10.5:1 actual static will be a problem for pump street gas and a closed chamber Cleveland head.
Next, it may not be a compression ratio problem. The Pantera does have this issue of the original design of the radiator fans causing engine run on after the ignition is turned off.
Lastly, these engines need 16 degrees initial timing at idle. They like 36 degrees total in "Boss 351" configuration.
They will not accept a fast distributor advance on pump gas. Best they will take is all in by 5,000 engine rpm.
The days of having full advance in by 2,500 rpm on pump gas are long gone. That is 106 race gas territory and even at that, they are very sensative.
IF you are going to attempt to add home made octane boosters be sure that the rest of the fuel system will accept it without eating the tank and fuel lines.
You also need to worry about the brass floats in the carb, or carbs (weber ida's use brass floats too).
Brass floats in the carbs should be changed out to the nitrofil types if you are using any kind of fuel with ethanol blended in. Here in the US that's everyone.
The stuff just eats up certain metals. Brass is not particularly immune to it although it seems to be on a slower digestive track.
If this is a compression ratio issue there is nothing that will fix it except a minimum real
103 octane rating.
I tried Sunoco 102 Unleaded racing gas and it did not solve the problem.
Also aluminum heads don't necessarily fix it either.
The cause is the inability of the fuel octane to resist detonation, which is igniting of the fuel just from compressing it. That's how a diesel engine works and that's why this is called dieseling.
