My clutch pedal sometimes go to the floor. If it doesn�t �catch� in the first �� it effortlessly goes to the floor. This happens about 1 in 8 times, but is getting worse, fact is I parked it.
Is the problem the master cylinder or the slave? I�ve looked at the repair manual and either one doesn�t look too bad to pull, but they leave out what to do with it once it�s pulled. I�ve seen threads in here about getting rebuild parts from 50�s Chevy truck sources. Is there a good article somewhere that address my problem?
