Well, So Cal has had some gloomy weather the last few weeks, rain, lightning, over cast days. Today was sunny so I dusted off 6018 & took it out to run my errands.
Well, the clutch pedal stopped working. The slave or master is dead. The car stalled blocking both lanes of on coming traffic on Hwy 126 (a rural stretch of road outside my home town). I had the emergency flashers on. All the truckers did was blast their horns. My life flashed before my eyes. A migrant farm worker couple, man & wife, came to my aid & helped me push it off the road. I shoved it in first hit the starter & drove it home in first gear.
My decision is to fix the clutch release system and keep it on the road for another month, until the PI gathering in December, or start the winter projects. What to do?
your undecided friend on the DTBB, George
Hi DeTom,
Situation like that makes one's rear end pucker. LOL.....
The pedal pushes in very easily now, it just doesn't create any hydraulic pressure & the clutch doesn't disengage.
The 30 year old master or slave have thrown in the towel. I'll replace both plus the red hydraulic hose will be replaced with a nice braided steel one.
What do you think, time for a buttery nipple, eh?
George
Yeah you deserve a good stiff BN George. When I did my engine last winter, I got a new master and slave from Hall Pantera. It even came with fancy colored nuts and everything. Give bev a call and she can have the parts to you by this weekend. Don't forget to bleed them after you install though. They take a whole lot of bleeding to get all the air bibbles out. I am glad you didn't get hit.
Maybe these things come in bunches?
George,
Absolutely! While on last weekend's PCNC Paso Robles wine tasting tour, my Quella internal hydraulic throw out bearing must have spun itself out of adjustment, and there is no pedal free play anymore. Which probably means that if not now, then very soon, the throwout bearing will start spinning with the pressure plate fingers, which will soon destroy the rubber quad seals (square o-rings) in the bearing. So rather than find myself in your 'dead on the road' position, I have a ZF removal chore also. By the way, I (along with Dennis Quella) do not recommend the hydraulic bearing for a street car. NO external adjustment, quad seals are known to dry out if not regularly used (not a problem for me), and a pain to set up properly. Cleans up the bellhousing look, but at a cost. I bought 2511 with this upgrade installed. Too much $$ and trouble to gather all the removed parts to return to stock.
Good luck George!
LOL.................
Mike my friend, I read your question a little while ago and I thought to myself, oh hell. Your question about the age of the fluid made me think about the "level" of the fluid! Well, I hadn't checked the fluid since the beginning of the driving season, last spring. At the time it was about 1/3 full. couldn't be I thought to myself.... no way.... I didn't even consider ....I was stuck thinking a 30 year old part had finally given up, I never considered to check the fluid level!
I ran downstairs a moment ago, popped the bonnet open & sure enough the fluid was at the lower limit of the plastic reservoir, you know, where the tapered bottom meets the verticle sides. I stuck my finger in the fluid to see how far above the connection to the master's port the fluid actually was, well, not much. DOH!
I poured some Castrol LMA in the reservoir and started pumping the clutch pedal and the pedal started getting harder to push. I started the car, pushed the clutch pedal & sure enough, I had clutch again! I can shift gears without drag or grinding.
Mike, you get the Sherlock Holmes award & I get the bumbling Dr. Watson award. Thanks Mike, I owe you one my friend.
your friend on the DTBB, feeling a bit foolish, George
