Auzzie heads are closed chamber! so the comp. ratio should be close to the same. The only difference is, ofcourse, the smaller ports. A head gasket of .043" may be a little thicker than stock (.035"??). I have also read of some machinists using 2 head gaskets. To lower the compression ratio, you can also: use a cam with more duration and/or valve overlap. Also you could Polish out the combustion chambers (increase capacity), or increase the rocker arm ratio (increases duration), although a ratio larger than 1.73:1 would be hard to find, and the stock ratio streeses the valve train enough already. Regards, Marlin.
Dan Jones, fellow P-car owner and having extensive knowledge of the 351-C and its various heads and intakes, has told me that 11 to 1 CR is very liveable with the Aussie heads (which I have in addition to the 4V closed chambers, though I have not yet run on the Aussies). His point is generally that the closed chambers produce a better squish/mixing of the intake mixture, reducing the likelihood of hot spots that would produce detonation. I think he has an article on Daryl's Stang Stable website under the 351C resources that may elaborate. He gave me the thumbs up on my build, having a Weiand Xcelerator intake, KB flat top hypereutectics with otherwise basically stock bottom end, and a moderate cam.
