You didn't say what year your car is, and fuse location varies depending on whether its a 71 or later. In early cars, all the fuses are in a small box above the passeners feet while in later cars the fuses are behind a hinged door near the passeners rt leg. Cooling fan fuses should be #11 & #12. All fuses & their intended use are in your red Owners Manual, on pg 65- I suggest Xeroxing the pg & glueing it to the door or inside the box. Just keep in mind that the DeTomaso Pantera is THE most messed-with sportscar ever built, and amateur hacks have targeted it for all kinds of"upgrades," some of which actually work.....so your wiring may be modified good or bad.
quote:Originally posted by canadian andrew: this is probably a stupid question but i was wondering where the fuse is located for the cooling fan is located?
sorry about the last one but anyway, i have a 74l with the fuse box right by the passengers right leg. i don't have the manual which is the fuse, my fans stopped working and i want to check the fuse first. thanks a lot jack
