does any one live close to 7649 19 mile road sterling heights mi, 48314 P A R E Race Engines im having a 427 dart with webers built wondering if any one has been there maybe drop in see how my engings comming togather?
its not a car its just a motor being built 427w dart iron eagle block 4.125 bore probe forged pistons dish top 10.1 compression 4340 forged h-beam rods 4340 forged crankshaft 4.000 stroke total seal ring set file fit clevite 77 bearing set pro comp cnc ported 225 cc heads custom hyd roller cam link bar lifters roller custom one piece pushrods fel-pro gasket set stacker webber carbs 48-50 mm with intake complete with linkage msd pro billet dist msd pug wires new oem timing cover water pump high flow polished tall valve covers comp cam roller rockers canton front sump 7qt oil pan melling high pressure oil pump arp oil pump drive billet roller timing chain set 28 0z balancer 280z billet steel flywheel est . hp....625 complete engine with dyno tune
Wayne, just let me know if, and when you need it checked out. Sorry about the confusion with my first reply, I was at work doing a dozen different things when I posted my reply. It sounds like a really nice set up. If you want I can send you my email, or cell phone #.
