Have a Edelbrock F351 manifold available. It has been polished. Not sure if it came this way or if a previous owner did the job. Not quite as good a quality polish job as seen on the current production manifolds, but not too bad. Could just use some touch up to it. Has helicoils installed on the carb base. Overall in good shape. NO porting has been done. No damage or cracks. Has a homemade block off plate on the heat riser that is fairly crude. Would suggest fabricating something a little more elegant. Located in San Francisco bay area.
$125
Jason
$125
Jason
Jason, do you have pics of the intake ports?
Thanks,
Steve
