For Jack or anyone please;
I've got a '73L and I installed a 100 amp alternator with built in regulator & one wire connection. I also have one of Gary Hall's new amp meters. When I start the car and idle then turn on the lights, the whole electrical system pulses (including the interior light) with the amp meter needle that sways back & forth across the "0". If I increase engine rpm the pulsing reduces but is there very slightly with slight amp needle bounce. All the ground wires check out.
Okay, here is the kicker. If I turn on the A/C, the pulsing stops and the amp needle stabilizes on nuetral. No bouncing. The whole electrical system stabilizes. Anybody got any experience or ideas on this?
Rodger
