I took out my radiator to have a leak repaired. While doing so, got a little ahead of myself in pulling the cooling tubes from underneath to clean and replace the rubber.
Didn't properly note which of my "left" or "right" tubes goes to the upper or Lower radiator hose? It appears you could reinstall either way, and yes, I feel like a dummy.
George, once the answer comes back, you can delete this post so my idiocy will not live on forever!
