They are called barrel clips, actualy I belive Ford uses them. My local NAPA does not stock them. The clip is tube shaped with a little lip that fits flush with the outside and on the inside dia. there is a tight end that grips the emblem pin. Try your Ford dealership and take your emblem with you........
