You can try reversing the upper mount-halves; they may have gotten mixed up side-for-side. Note- there are two different upper mounts: one has a single hole, offset from the center of the pad, while the other type has TWO holes. This type can be used in either position- left or right. Finally, you can drill holes in the upper pad to correspond to whatever engine position you'd like- the further back the powertrain is positioned, the more room your engine will have for a big-cap distributor, etc.
Pantera chassis were welded up at the factory on a variety of weld-jigs and not all cars had the engine positioned at the exact same spot. The ZF mount-tabs are thin and flexible and bend easily with a hammer. I reversed our upper engine mounts and bent our 1972 ZF tabs into a shallow 's' shape. This allowed the engine to slide back nearly 3/4" inch from the stock position, so the front sump of the oil pan was not quite touching the crossmember under the engine. It helped considerably in producing an 'almost-flat firewall' access door, for more interior room and the mentioned big distributor cap. See articles in past POCA Newsletters on the subject.
thanks Boss,
I have the single hole pad but im thinking its the lower mount or pedastool. also if i switch mounts from side to side it will move the mtr. back 3/4 to 1" but i may have spark plug issue on the left head @ fender well. also my 71 has sharp bent inner fender wells at the rear of the sus. reinforcement area. all else is rounded. not to be confused with european type. thanks larry
