Originally posted by deeb:
I disagree totally. I did the bedliner and undercoat treatments on my old car and it was impossible to get the dirt out of the texture. Especially when it gets oily and greasy as it most certainly will.
Since I painted it satin black, I can use a dust mop when it's dusty and it looks brand new in seconds. When it's greasy and oily I use any simple degreaser or cleaner and it's shiny and new in minutes.
Next time I have the engine out I will fill in all the stupid rain- catching edges, useless holes and rough edges, then finish it like bodywork and paint it high gloss with a clear coat. So there...
Well, we don't disagree totally. The high gloss paint would be great and I agree that a heavily textured surface isn't, but I've seen a pretty smooth finish on some of the epoxy bed-liners that is easy to wipe clean AND is scratch resistant. Here’s another piece of advice: get some foot square bits of sheet steel and test each finish and then kick them around in the dirt & grease before committing. It will cost a bit more to test them, but you’ll be more confident about which choice suits YOU best. Good luck!
