Dear All,
I am trying to work out how to improve the engines cooling. I found that the current setup of having one cam belt run across the water pump is insufficient and by far to dangerous when running at higher revs. I would like to setup so that there are at least two cam belts running across my water pump. Does anybody have any ideas where I could find a double grooved pulley that would fit a 351c.
Thanks for your help.
Tom
