Installed the engine and trans on Wednesday, well nearly, Have a problem the right side fits perfectly, while the right side needs to go back 1/2 an inch. the top donut is not sitting mount correctly and we have already have all the spacers to the front of the trans mounts. is there any play in all the mounting brackets or has my car shrunk/
and yes engine mounts installed with holes to the front!
cheers and merry Christmas to all
are you talking about rebuilding the plate on the chassis or modifying the engine brackets?
Originally posted by suburb:
Reading this makes me uneasy, because I had to remake the plate on witch the motormounts are bolted. Checking the measurments of the holes, i found that there was 1 centimeter difference between left and right. so now the holes are both indentical i hope the engine will fit
