...On My car the hose ran Straight forward, towards the nose, Through the Sheetmetal bulkhead, to a 'space' that was 'open' downward to the street(if you get under the car, you should be able to find a 1 Inch round Hole). There, the Hose became a 90 degree angle, about 6 Inches in length, pointing Downward. So the condensed water would run down the outside of the Bulkhead and onto the Street.
When I cut open the trunk floor to Do a 'Dropped Battery', the hose was in the way, so I cut it off flush with the bulkhead. I didn't need it, as My AC has been disabled and removed from the car. But the Heater and Evap. Core still remain.
