Apparently the tach you're trying to hook up is grounding the coil rather than only tapping or inducing a small amount of voltage to move the gauge needle. A MSD tach adapter MAY work, but I would certainly call them for advice before ordering this. Did this tach ever work on a Pantera? You could of course try it on the positive pole of the coil, but I suspect it won't work that way.....
