Well, after 6 years I drove #6214 for the first time. It moved all the way from the garage to the driveway and balked the whole way. After much tuning (and cursing)I decided to take one quick tour of the cul de sac. After numerous attempts at keeping the engine running while engaging the clutch (back to the tuning issues) I took my first cruise in the beast. Its amazing how after all these years of building the car it could be so tough to enjoy the first drive. Between scanning the oil pressure, water temp, listening for any noises, and keeping the engine running, there wasnt enough processing power for the pleasure center of my brain. Anyhow after a quick blip of the thottle resulting in immediate traction loss (couldnt resist) back in the garage she goes. Next on the list, interior and tuning. Lookout Italian days in June #6214 is coming.
Let me be the first to congratulate you, Blaine. Fantastic news! It's great to see the incredible amount of thought and work that has gone into your car coming to fruition. The sedate retiree lifestyle of your neighbours will never be the same after your beast starts prowling the streets of Victoria!
I can't wait to hear that crazy motor of yours run.
The publishers of this web site should be pounding on your door for permission to feature your car in PI International Magazine before POCA Profiles beats them to the punch.
The British Columbia Pantera scene is certainly heating up!
- Peter
The work was more or less completed in September, just barely in time for another exotic car trip through the mountains. The car was not sorted properly before we left, so the trip was a disappointment. A power wire pinched behind the alternator meant we went through three regulators before a Canadian Tire mechanic in Vernon finally diagnosed the problem. There were lots of other electrical gremlins, plus a clutch that needed repeated adjustment to keep from slipping. To cap it all off, the new 427 started running poorly as a result of the carb running way too rich. It was also a bear to start on the cold mountain mornings because the vendor sent the engine with a carb that has no choke. IMHO, this may be fine for California but not the greatest plan for a car to be run in Canada.
I also kept hearing a ticking that sounded like a header leak but, on pulling the valve cover, it turns out the problem was more serious. The exhaust rocker arm was either not installed properly or slipped off shortly after it began running. It was cocked sideways and the roller was actually riding on the top of the valve retainer. It was like this long enough to substantially wear into the valve retainer. Eventually the retainer would have broken, dropping the valve into the piston.
Another problem I ran into is that the new motor did not come with a puke can or a PCV system, so oil kept dripping out of the breathers onto my headers. It was embarrassing being followed by a cloud of blue smoke everywhere, and we found the smoke was getting sucked into the passenger compartment meaning we probably both emitted and breathed our lifetime LA smog quotient in one trip. I’m also less than happy with the resulting discoloration on my newly Jet-Hot coated headers. The crate engine vendor had no solutions, so I turned to Hall for a nice billet aluminum PCV system that’s being installed as I write.
We had to keep the speed down for the first part of the trip in order to break the engine in, and by then the motor had started running so poorly I didn't want to push it hard. Even so, I can say the car really flies now; anything more than half throttle and I'm just hanging on for dear life. I can't even imagine what your car will be like to drive with twice the horsepower.
If you want to see some photos of my car after the restoration, have a look at the following links:
http://pantera.infopop.cc/eve/forums/a/tpc/f/155004...470074093#7470074093
http://pantera.infopop.cc/eve/forums/a/tpc/f/155004...730059683#3730059683
http://pantera.infopop.cc/eve/forums/a/tpc/f/155004...210059683#4210059683
http://pantera.infopop.cc/eve/forums/a/tpc/f/155004...430051683#9430051683
Currently, I have once more torn off my (newly refurbished and powdercoated) control arms and steering rack, and sent the works to Pat Mical for his ministrations. I am determined to get rid of the wandering and tram-lining. While I'm at it, I'm going to install new fully adjustable Koni gas shocks with 2 1/2" Hypacoil wire. Once the car is back together, I plan to take it to a specialty shop in Edmonton that can do the bump steer tuning and corner weighting for me. Pat has offered to talk us through this over the phone. After that, it's off to a specialty dyno tuner in Calgary to try to sort out the carb jetting -- since the crate engine vendor was no help there either.
In short, I empathize with your not being able to enjoy your first drive because of all the maiden voyage trials (to use a nautical metaphor, just between us sailors).
  • rocker
The car looks great Peter. Its hard to believe you went to the extent you did and managed to get the car back on the road so quickly. I am sorry to hear that your first run with the gang was lessened by engine troubles. Especially ones that you wouldnt have expected to see creep up. I suppose it turned out pretty well compared to what the outcome could have been. Hopefully you will be able to make it down this way this year. Maybe I will have some parental backup so we can perhaps go for lunch or at least a coffee.
Blaine
