Well the engine is not that easy to get to. And the fuel tank can only come out if the engine comes out. But over all it's not that bad. Just watched a few episodes of Wheeler Dealers. First a Delta Integrale. To get to the alternator, the right suspension had to come out. To change the radiator, the grill and bumper and hood had to come off. Then an Audi Quattro from the 80s. To get to the clutch slave and bleed it, steering rack had to be moved. To change a rear wheel bearing, suspension had to come off.
Fixing Panteras is pretty easy I'd say... Compared to my boat even more so...
Danish, the method that almost always works for shops when removing stuck fuel tank drains is, use an air gun! Set the clutch to a fairly low pressure and let the gun hammer the fitting for awhile. It WILL come out. The reason is, long slow twists of the plug with ever bigger wrenches will visibly wrinkle the very thin steel in the tank bottom, possibly tearing it before the threads let go. By using an air gun, the tank bottom will not be damaged.
The second way is drilling the plug out. Ideally the tank should be empty while drilling, especially if you use an electric drill!
if your going to remove the fuel tank most of the gunk will fall out turn your tank so that you can put some penetrating oil on the bolt. let it set for a day or so put a wrench on it and tighten then loose then tighten then loose it might loosen the threads. don't use heat unless you are sure of how to use a torch to expand the threads without expanding the bolt and be careful of residual gas or fumes in the tank.
