351C has only been run on the dyno. The corrected power is 320.2
hp at 5100 (max) and 341.7 ft/lb torque at 3700 (max) with a Holley 750 (not included).
Here are the stats:
bored .030
230-234 Comp cam
9.2:1 compression ratio
TRW small dished pistons
springs- 140lb seated/380lb open
Johnson hydraulic antipump up lifters
Harland Sharp roller rockers
3 main bearing restrictors
intake and exhaust flow plates with epoxy
flow kooler aluminum waterpump
pushrods (p/n crn5262116 from summit racing)
Offenhouser 360 single plane intake manifold
I have all the paperwork from the dyno and pictures are available. Email me ( fankkey@gmpexpress.net )
if you are interested.
