Thanks for the info! I'm changing mine to match the other VDO gauges I've installed. Is there a certain sender I need? I noticed they make several.
And another question:
Like an idiot, I disconnected the fuel gauge without labeling everything in case I wanted to put it back. Well, now I'd like to put it back in until I change the sender. I've studied my wiring diagram but am not sure where some of the wires go on the gauge. The only markings are for "+" (the pink wire) and "com"? Which terminals are for the ground, sender, and low fuel indicator? What an idiot..... learned my lesson on this one!
thanks,
-Richard
