Bonjour,
I have on my Pantera an electric fuel pump (red Holley) installed directly connected to a 750 CFM Holley. I have seen that some Pantera owners have installed a fuel pressure control device and a fuel return line. I was wondering about the benefits of this modification. Is it worth implementing this modification and what is your own experience related to the benefits?
Brgds
Hartwig
You don’t mention anything about a fuel filter in your system?
A return line is definitely needed on a high pressure fuel injected engine. Generally not installed on a carbureted engine as long as pressure is kept around five or six psi.
as mentioned above it could provide relief from boil over on a heat soaked engine and a return line is not likely to cause any problems.
