NO PROBLEM! I DID IT, REMOVED THE CANISTER ALSO. CLEANS UP THE LOOK OF THE ENGINE COMPARTMENT. MAKE SURE YOU CAP THE VENT, UNLESS YOU LIKE TO SMELL GASOLINE FUMES. (I USED A HIGH QUALITY VACUMN CAP AND MINI HOSE CLAMP) BUT DON'T CAP IT UNLESS YOUR FUEL FILLER CAP IS VENTED, OR YOU WILL BUILD UP VACUMN IN YOUR FUEL TANK TO THE POINT THAT THE FUEL PUMP WILL BE INEFFICIENT! HOW DO YOU TELL IF THE CAP IS VENTED?? PUT THE INSIDE TO YOUR MOUTH AND SUCK, IF IT ALLOWS AIR TO PASS, YOUR IN BUSINESS!! GOOD-LUCK, MARLIN.
