I have noticed that on some panteras there are 2 gauges one on the side of the speedometer and one on the side of the tachometer. Is this a custom job? Or did the pantera factory install these on later models?
Late model Panteras had a factory installed oil pressure and oil temperature gauge installed to the right and the left of the speedo/tach... Is this what you've seen? I don't recall seeing two gauges to any one side, but my car has one on each side...
------------------ Charlie McCall 1985 DeTomaso Pantera GT5-S #9375 "Raising Pantera Awareness across Europe" http://briefcase.yahoo.com/gt5s_1985
