Originally posted by jack deryke:
Definitely a mis-adjusted shift linkage. Once you've done it, this takes less than 5 minutes to adjust. The easy procedure is in the Owners manual and simply involves shortening/lengthening the shift rod at the transaxle end.
Thanks very much for your very quick reply Jack. It was the only thing that worried me about the car.
