Gents,
I bought the GTS exhaust headers and mufflers from a good Pcar vendor. I bought them just about a year ago and have been sitting in boxes since then. I am pulling the current Mind Train system off as it is TOO LOUD, like ear plugs after 20 minutes. The new headers bolt on to the heads just fine. But the mufflers, the tips hit the rear one piece rear bumper on my 1974 Pcar. The muffler pipe, just to the rear of the header collector clears the half shaft correctly but hits the chassis "tubes". As in the tubes that run up and the upper control arm mounts to. Muffler "can" is at an angle going upward toward the rear of the car and is to high and hits the under body. SO WHAT do you think???? I think the tips needed to be bent down so that they are level with the ground and miss the bumper. Do I have the pipes for a Pre-L or what?
Thanks for the input.....Doug "with my tips up" Hartmann
