Can someone answer this for me? In a plan view, (top view), are the half shafts on a zf-1 transaxle 90 degrees to the wheels. I had a new tube frame built for my car and I noticed that my half shafts, in a plan view, are not 90 degrees. The center lines on my transaxle, where the half shafts plug in, are about an inch rear-ward of the centerline of my wheels.
That orientation should not cause any issues.
Actually, u-joints NEED some mis-match to properly function.
The angle of the u-joints is greatly increased with big block engine swaps, but the stock u-joint assemblies have proven acceptable.
Although I have recently heard there are some who now feel the big block angle is too much and CV joints are perhaps a better solution.
Again, your 1" mis-match should be just fine.
