Just be careful with increasing the amperage of the bulbs you use beyond that used by the stock bulbs. The stock headlight wiring routes all the power through the headlight switch, which is not of real high quality and will literally fall apart as the contacts burn off. Many Pantera owners add relays to lengthen the life of the switch and other components.
Sylvania Halogen part number H6024. "50% Brighter than incandescents!" Available at any auto parts store. About $8.00 each. To install: ingnition ON, Head Lights ON, ignition OFF. Headlights stay PU. Just loosen the three retaining screws holding the SS bezel, rotate 0.375" and bezel comes off. 3 more scres to remove lamps, and reverse the procedure. 10 to 15 minutes.
