Interior is still out and I noticed when I took the door opener off to do some paint touch up (not correctly installed and damaged the rear of the cutout in the door skin) that the buckets left and right where broken and also the handle return spring on the driver side was broken…you can see the cracks on the webbing going up from the spring!
I sent the passenger side opener to Larry, @If-tp2511 and he artfully made the lock fit the key I had and he also replaced the not shiny trim around the lock cylinder and the little door of the cylinder!!! Now the lock works and it looks like new… aside from the broken bucket…
I got the new buckets from PIM and they came with new pin and clips to hold it in place
Soaked the pin / handle with WD 40 (on the drivers side the pin was rusted into place and I had to dissected into small pieces to get it out ) drilled out the top of the pin carefully and tap the pin out
