THERE ARE 4 WIRES GOING TO THE SWTCH.(PINK-POWER IN FROM AMP GAUGE MINUS SIDE.WHITE-POWER TO HIGH/LOW BEAM SWITCH. ORANGE- TO INSTRUMENT AND PARKING LIGHTS. RED= TO HEADLIGHT DOOR RELAY.)BUT IF YOU ARE GETTING HIGH BEAMS THEN YOU HAVE POWER FROM THE HEADLIGHT SWITCH TO THE HIGH/LOW BEAM SWITCH!! SO YOUR PROBLEM IS EITHER BURNED OUT CONTACT FOR THE LOW BEAMS IN YOUR HIGH/LOW SWITCH, OR THE WIRE FROM THERE TO THE LOW BEAM FILAMINT. FROM THE HIGH/LOW SWITCH TO FUSE BLOCK, ( THE PROBLEM COULD ALSO BE THE #5 AND #6 FUSES) THE WIRES ARE: LOW BEAM= GRAY. HIGH BEAMS GRAY/BLACK (FUSES #1 AN #2).THIS IS ACCURATE ON A 74L! GOOD-LUCK, MARLIN.
[This message has been edited by MARLIN JACK (edited 05-14-2002).]
