Gently slide a piece of thin steel like a feeler gauge between the u shaped piece that holds the levers on and "lightly pull. does not work on the early cars
ps anybody need a set of early car heater levers, plate and cable???? make me an offer!
Hi Guy's thanks. Dave 2811 , this is not what I want to do , I only want to pull the chrome extensions whitout demount the whole unit. Joe 1974L , I go try your advice. Regards Simon
