I installed a new aluminum lay down radiator and a couple of heater shutoff valves.
Everything has worked fine but on two occasions when the outside temperature was near 90, I have experienced overheating. Yesterday, it blew past the pressure cap on the expansion tank and just kept boiling...big time.
I either did something wrong with those shutoff valves, or I hooked up the radiator backwards. Or...something else?
The temp guage never read over about 165.
The two hoses going through the firewall are AC hoses so I left them alone. The two coolant hoses that go down under the tunnel are the ones I put the shutoff valves in. Was this wrong?
I'm sure I got the radiator installed right, but my car didn't have a vent/overflow tube from the radiator back to the expansion tank. There is no place to attach it to the expansion tank and I was told it wasn't necessary, but it was a good idea to have it. What do you think?
I think that some temp guages were hooked up at the expansion tank. Mine doesn't seem to be this way. I think the sensor is somewhere else in the system. What is the best way to get an accurate temp reading. Something is fishy here.
My new puller fans are working properly, so it is not that I don't have air flow.
Sheesh...I had less problem with the stock set-up! Haaalp!
Mooso.
