There is a heavy gauge blue wire coming off the pas side of the blower under my dash, it's attached to the resistor on the side of the squirrel cage fan... Where is this wire supposed to run correctly from the factory??... This car had it jumped off my power windows at the isolated fuse block??... that can't be right?.. Thanks for any help or advice...
Thank You!!.. Hmmm, this calls for a black wire?.. I really can't beleive this car has not burned down, every wire is spliced, jumped, elec taped, burn marks on the fuses, melted spots on the insulation... Scary bad, the worst I've seen. I am seriously considering pulling all new wires through this car. It looks like a painless kit will run this car. I'm gonna' give those guys a call and check it out.
