For me it looks like it works as must be, the stricker always must have 2 clicks .
Maybe your striker on the door post is adjusted wrong and when you close the door it gives 1 click the door lock cannot came into the lock position.
when the upper mounting screw from the lock mechanism is to long , it also not will work .
Not needed to take the window out , only one bolt on the lower of the slider inside the door and a screw just above the door lock mec. on the outside of the door and you can take out the slider .
Sometimes the slider rubber is glued , but take out only the steel slider part.
Window must be into the closed position.
AE05E001-19DD-4D79-9514-ECCF4040D96EThe …striker… is the “pin” attached to the B pillar. It does not move.
The …latch… is attached to the door. The portion of the latch that engages with the striker is the part that moves.
I understand Riley’s …latch… mechanism moves. I was not talking about latch movement.
Reilly said his …key… would not turn.
I just inspected 2511. It does not matter what position the latch is in; a correct key will always turn.
His latch mechanism may well need adjustment.
Also, after 50 years, his key and lock cylinder may be mis-matched.
  • AE05E001-19DD-4D79-9514-ECCF4040D96E
None of the videos show a …key… moving.
What is shown in the videos is the gray pot metal piece (it has a ball on its short arm that engages with one of the plastic pieces at the end of the short rod) at the rear of the lock cylinder moving.
that short arm CAN be moved by turning the key, and ALSO by pulling the door lock knob up or pushing it down
The fact that it moves does not indicate the key is correct for the lock cylinder
RILEY ‼️‼️ Please chime in and clarify exactly what you meant when you said
the key won’t turn
Ah, ok, than if you have luck spray some WD40 or other creep oil , inside the key cilinder , try to get in and out the key several times ,  maybe the brass pins are bestuck , otherwise take out the cylinder place the key in the cyinder and grind the brass pins what are sticking out.
Then the cylinder is modified to your key.
Traditional lock lubrication is done with powdered graphite. It comes in a small squeeze tube resembling a toothpaste tube.
There is a specific aerosol made for locks that goes by the name Houdini. A web search will find it, it is not very common.
any petroleum-based product, such as WD-40, will act as a lubricant but will also act as an attractant for dust and it will gum up the lock in the long run.
@lf-tp2511 posted:
At Larry's Recommendation, I got Houdini. You can get it on Amazon.
