JACK
JUST FINISHED ABOUT A 500 MILE BREAK-IN AFTER A CAM (HOWARD 614/630) AND HEAD CHANGE. uSED 4V CLOSED CHAMBERS HEADS,STRIP DOMINATORINTAKE, EXTERNAL OIL LINE,TALL MOTORSPORT VALVE COVERS WITH MOTORCRAFT PUSH IN BREATHER. SO TO THE PROBLEM AT HIGH RPM AROUND 6500 OIL PRESSURE GAUGE PEGS AND OIL SLINGS FROM BREATHER ONTO BACK GLASS ALSO
CAR HAS NEVER LEAKED BUT STARTED DRIPPING OIL FROM ZF WEEP HOLE AFTER HARD RUN.
SHOULD I CHANGE TO A K&N BREATHER?
USING A BILLET PVC MAYBE CHANGE IT?
