What I have:
Horn marked 9834-3 2023.
The base is marked 4585 with a date stamp of 5/93.
From one of my Holley books, it decodes to a 4160. (600 CFM, elec choke, vac secondary.)
I'd like to convert from side hung floats to center hung, and swap the sec metering plate to a metering block, along with duel fuel supply lines.
I have an old 4777 that can donate the metering block, and fuel bowl(s), #47772 - 6497, (76 - jets) my preferred choice,
or one that is part of a 4160 to 4150 upgrade pack, with a # of 4100.
Can I just swap in the secondary metering block, using the current primary block, or should I use both metering blocks from the 4777 ?
Chuck
