Hi, my pantera has the timing too retarded, i believe, the timing marks are they on the balancer like a anormal clevland ? or is there something on the flywheel for easy access ?
if on the balancer then it is a seat out job !!
Also where is the engine number on these ? is it the standard spot, above the fuel pump ??
as my guy will need to read it for registration.
Thanks in advance.
