I have recently bought a 1974 Pantera with 17000 miles on it. The bad part is the problems that come with not being used much. The gas tank has rust in it and will need to be removed. This means taking the engine and transaxel out. While they are out I plan on doing the following. Please note this car will be for semi regular use with no hard driving planned.
1. Replace the water pump. Is a stock one OK or
should I go for a high performance one?
2. I will replace all the cooling system hoses
with silicone style hoses.
3. I bought a new A/C compressor and all new
A/C hoses.
4. I bought all new belts.
5. New front and rear main seals will be put in
the engine.
6. Since the radiator leaks I will buy a new
aluminum Fluidyne radiator with sensors.
7. I will check the ring gear in the ZF for
safety wire.
8. Electronic ignition will be installed.
9. Should I buy a new timing gear and roller
chain?
10. The car has the original Motorcraft carb.
Should I replace it? With what carb? Why?
11. Should I buy the stainless steel water
tubes under the car? Copper ones? What?
12. I have new gears for the windows and
lights.
13. Since the radiator leaks should I replace
the heater core?
Is there anything else I should do while the
engine is out to ensure reliable driving
with a minimum of problems? I am 63 years
old and want to enjoy the car without
working on it too much in the future.
Thank you for your help. You can e-mail me at oldcars@comcast.net if you do not want to answer on the forum.
> on it.
Mine was similar with 16K miles when I bought it.
I have a few suggestions.
Stock with a Flow Kooler plate on the backside
of the impellor would be fine for an engine like
yours.
Silicone hoses are fine (I have them on my Mustang)
but nick easily so you should use the solid type
clamps. Most of the vendors use Gates green stripe
standard hose which are fine with the usual band
clamps. I have those on my car.
> chain?
Yes. The stock timing set uses a plastic coated
aluminum gear. Use a quality double row true roller
timing chain set (J.P. Performance, Cloyes, FRPP, or
similar). Inspect the balance for dry rot. If it's
ok, paint a stripe on for a positive indication of
balancer slip.
Not unless you are modifying the engine substantially.
The Motorcraft 4300D is calibrated to your engine and
flows 715 CFM. Mine worked fine. If need be, put a
rebuild kit in it.
Mine were in pretty good shape so I just painted them.
Time kills the seals and rubber. Replace all the
vacuum hoses (mine were original). Replace the suspension
bushes (mine were dry rotted). I installed polyurethane
bushings and used the offset bushings to gain extra
caster up front (good for highway stability). My shocks
were fine but the rubber bushings were ovalled. Repack
the wheel bearings. Flush the brake fluid, replace the
brake hoses and rebuild the brake calipers (kits are
available). Rebuild or replace the clutch slave and
master. The motor mount rubber donuts may be compressed
to one side. Your can turn them 180 degrees and get
some more life out of them or replace them.
The most important thing is to R&R the cylinder heads.
The stock valves are made from two pieces, friction welded
together and use loose fitting multi-groove keepers (the
keepers halves contact each other instead of being wedged
against the stem by retainer). If the valves don't slip
out of the keeper, they'll pop the head off the stem.
Aftermarket tight fit multi-groove keepers are available
but you still have the 2 piece valve problem. Use single
piece stainless steel valves (Manley Severe Duty, Ferrea
6000 Series, or Milodon Competition) with single groove
locks and retainers.
The umbrella valve seals will likely be hard. The umbrella
seals disinegrate over time and fall into the pan where
they get sucked up by the oil pump, momentarily locking up
the pump and bending the shear pin. Newer umbrella seals
are supposedly made of a more durable material (the last
rebuild gasket set I used had a note to that effect) or
you can use the blue or black viton seals. The white Teflon
seals with the upper ring are too effective and do not allow
enough oil past for lubrication of the stock cast iron guides.
This can lead to a stuck valve or prematurely worn guides
and/or stems.
Drive a second shear pin in the distributor gear or replace
with a hardened pin. If a little debris gets in the pump
gears, it can shear or bend the pin. This retards the timing
which leads to sluggish performance and overheating, if the
engine manages to continue to run at all.
Make sure you have the Cleveland specific thermostat
and the brass restrictor ring is installed in the block.
They have a shoulder which is sized to match the brass
restrictor ring in the block (make sure it's there) which
other thermostats do not have. Using a Windsor thermostat
(which the parts counter monkeys will give you half the
time) will lead to over-heating because coolant will bypass
the radiator. Don't run an excessively cool thermostat.
It won't make a difference in steady state temperature
but will slow warm-up time. I recommend the Robert Shaw
351C thermostat. It's quick acting and has bleed provisions
(ball bearing check valve).
The usual Ford oil filter has a bypass valve bult into the filter
which can allow unfiltered oil to bypass the filter. The bypass
can also fail, causing a loss of oil pressure. Consider using
Purolator oil filter number L30119. It's a full size replacement
for the FL-1A Ford/PH8A Fram filter. It has no bypass spring
in the middle but it does have the rubber flapper for anti-drainback.
The original application is for a 1978 Nissan 510, 2.0L 4 cyl engine
(L20B) which had the bypass valve in the engine block. This filter
cross-references to a Fram PH2850, a Motorcraft FL-181, and a Wix
51452. However, those filters have not been verified and may
still have the bypass. It appears after 1978, Nissan went to a half
height filter. Purolator part number L22167 fits that application
and does not have the bypass spring but does have the rubber flapper
for anti-drainback.
The rubber intake manifold gasket end seals can be troublesome.
Many builders toss the rubber seals and just lay down a bead of
RTV. I don't like that as I've seen too many engines with RTV
bits clogging up pushrod holes and oil pick ups. I prefer to buy
or make my own end seals from cork. I peen the block rails with
a punch so the gasket won't squeeze out while it's being torqued
down (a problem when the heads have been milled but not the intake).
This also works well on valve cover gaskets. Use Permatex 300 or a
contact cement to hold the gaskets in place. Don't use RTV except
in the corners of the end rails. Retain the turkey pan unless the
carb heat ports are blocked. The pan protects the oil from splashing
on the hot exhaust crossover port and turning to ash.
Just my 2 cents,
Dan Jones
You should also maybe go to Mikes Panteraplace.com. He has a lot of handy tips to keep little things from going wrong, like adding a secondary means of opening the front trunk if the primary cable fails and all kinds of things that cost hardly anything to do but can save you headaches later on, like how to wire your headlights so they won't burn out your ignition switch/ It is really a treasure trove of Pantera tips.
I would suggest checking the bushings in the rear carriers and the rear axle bearings. I just went through a similar exercsise as you. The more I drove the car the more things showed up. I lost a rear axle bearing and when I took apart the uprights I found the lower shafts were seized and badly corroded. The universal joints were dry and rusted. Just a suggestion.
Good luck
Richard
Oldcars, that depends on your intentions for the car. Keep in mind you have obtained a "Factory correct" car, a near virgin which are getting hard to come by. I would bet money that if you entered it in the Seattle Italian concours this labor day weekend, your car may very well take first since I understand concours cars are judged on correctness. From what I know so far, your car would be the most "correct" car in attendence.
Ron
It may be the most correct car at the show, but it would have to be trailered there, and pushed off the trailer. With the rust in the tank it is hard to keep it running for very long. Then there is the leaky radiator, the 32 year old original hoses that leak in several places, the very noisy valve lifter, the clutch that only works after it is pushed several times, etc. I want a car I can drive reliably that will be as close to stock as possible. That is why the radiator will be recored, all of the hoses and belts replaced, heads rebuilt, water pump replaced, motor mounts replaced, front and rear engine main seals replaced, new timing gear and roller chain installed, ring gear safety wired, etc. It may be factory now but it is not drivable.
I quickly read all the posts, Dan did his usual thorough job, kudos Mr Jones. But I think I spotted two omissions, the fuel lines and the radiator fans. You must replace the rubber fuel lines, including the large one for the fuel filler, and the smaller one between tank & carb. The electric radiator fans are inadequate. One very common upgrade for those wanting to install something better in the stock location are the Meriah fans. Ask around, or keep your eye on e-bay, a set will turn up. I suggest you consider a relay upgrade for the fans, to take power for the fans out of the ignition switch circuit. If you're installing an electronic ignition, I highly recommend a relay to power the ignition also, as the power for the ignition also flows through the ignition switch.
For a water pump I recommend the Edelbrock #8844, and for a timing chain I recommend the RollMaster #08320. Getting the balancer rebuilt by Damper Dudes would be good insurance too. Run Shell Rotella T or Chevron Delo 400 motor oil, 30 weight if you can find it on the shelf. I buy mine at Wal Mart. If you have a hard time finding a true Cleveland thermostat, try Flow Kooler. Its a Robertshaw, part number 333-180. See the attached pic.
the cowboy from Hell
  • thermostat_images
