The key binds up and it just won't turn. After enough fiddling on every start I can eventually get it to work but its now beyond frustrating
I had a similar problem to what you're describing, and discovered after some searching that the ignition switch has a little spring inside that is supposed to hold the tumbler out until the key is fully inserted, then it slides in 1/4 inch and you can turn the key. If the spring isn't in top shape, then the tumbler can slide in early, and you won't be able to turn the key.
I gave it a blast of graphite lube, and it is much better, but not perfect, so if the tumbler slides early, I just give a slight twist to the key (to put a bit of binding pressure on the tumbler), pull back on it to bring the tumbler back out, then slide the key the rest of the way in and away it goes.
Have a quick read through what Ralph Granchelli has posted on the ignition switch, it may help ...
http://www.panteraplace.com/page125.htmOr, start at the bottom of page 58 of this document, it describes how to deal with some of the idiosyncrasies of the switch...
http://www.banzairunnerpantera...pgrade_tech_info.pdfI used to keep a straightened paperclip with a small 1/8 bend at the end on my keychain so I could pull the tumbler back up, but after the lube and a little practice, I was able to do the trick with just the key.
Hope this helps
