I just wanted to be sure that I shouldn't be able to adjust my emergency brake until I bleed the system.
I think the pistons need fluid in them to move outward to their initial limits, then the e-brake adjustment can be performed...
Right now, I'm waiting on a fitting, and so there is no fluid in the system. When I tried the e-brake, it tightened everything up, but the pads are not tight on the rotor.
It makes sense to me (but I just wanted to confirm).
Thanks -
