hi all
this week a bit of work is going to be done on the front trunk area while my master cylinder travels to california for a rebuild.
in the front trunk area, on the inner surface of the wheelhouses on each side are 3 rivits that appear to stabilize the top of the "tower" to which the shock assembly is fastened.
i searched this forum to see if anyone has had problems with these rivits popping or if anyone had replaced them by welding the "shock tower" to the wheelhouse, but i found no results.
am i just worrying about something not worth worrying about??? or should i just weld them up??
thanks in advance
nazgul
