I removed the L front bumper and installed the Amerisport mini-L bumperettes as the quick and dirty interim solution. Eventually I'll have the holes filled in, the front repainted and I'll install the European mini-bumpers (which I recently acquired).
I had the Amerisport bumpers painted black, however in retrospect I think they look better painted body color.
  • amerisport_front_bumpers
Originally posted by Garvino:
Tons of grinding - fitting, grinding - refitting, and so on.
I put the Stainless bumpers on my 74 that are listed on Ebay. Same story... Took at least 4 hours per bumper to get them fitted to the car. Blue painters tape and a pencil, mark the high spots and shave it down, again and again. A mini grinder with abrasive flap discs worked well but you have to be very carful. I double taped the bumpers and more than once accidently burnt through the top layer of tape. Could have been a trip to the polisher.
Steve
Where can I obtain a front and rear set of the euro-spec GTS bumpers? The front turn signal light is built into the bumper. I will take steel ones or fiberglass.
Thanks.
