laying down. Mine is the largest aluminum condensor that will fit and it's against the
Fluidyne radiator with only a foam sealing strip in between. There's only 1/4"
clearance to the old fan mounts as you may can see below. It's a very tight fit! I also
have a Sanden rotary compressor and a new aluminum evaporator under the dash. I'm running
R134A and I get down to as low as 39� at the vents on a hot 95-100� Georgia day. I
relayed the sucker fans straight off the starter solenoid with a 30amp breaker and using
the thermostat switch on the radiator and the A/C clutch to trip the relay. That way the
fans come on when the temp gets to 180� or the A/C is cut on. You have to use the breaker
unless you want to use a larger fuse than 30amps because the initial draw will sometimes
pop a 30amp fuse and the breaker will reset itself and you'll still have fans. So far, my
engine temp stays below 180� even with the A/C on.
[qb]Use the strip to block the air from going over the top and not
through the fins[/qb].
[qb]Here, the dryer is nestled tightly below the headlamp bar and
can still be viewed easily.[/qb]
[qb]Notice the condensor size, which goes all the way to the bottom
nicely.[/qb]
My next project will be to make two custom water tubes and a stainless shroud which
will allow me to move the fans back at an angle.� That way the air will move over the
entire radiator fins and not just where the fans are.� This should also improve the
capacity for cooling.
[This message has been edited by Pantera1252 (edited 06-25-2002).]
Originally posted by Pantera1252:
YES! I did just that, although you may have more room with it verticle instead of
nicely.[/qb]
What are the measurements of your condenser?
