hi there all ,have a dig through your spares,i am looking for a full set of four bolt mains caps in good condition for my block,cheers Kirin
up or is locked away,so i have to look further afield,i did see a set on a
trade site in the us,but they were already sold,i have found a block
locally that is standard bore,4bolt d2ae,but alas no caps.ill keep looking
,and as you say someone will have blown up a 4bolt so the may have the
caps i need.I have a very good two bolt block thats been sonic checked
.....but a four bolt is the gravy.
I think I may have a few sets. Not sure about shipping to NZ though??
Do you have experience shipping parts from the US to NZ?
Ron
I am far from an experienced engine builder but over the years I have picked up that most of the engines we build for our Panteras fail to reach a point that actually requires four bolt main caps for engine longevity.
Can you share what your plans are and why you think they need four bolt caps?
know the price for caps.then ring fed ex with weight and diamensions .ill
give you the address.kind regards kirin.
the basis for my next motor.
I have a 1972 ford fairmont hardtop that im restoring .it will run this
block but with 70 boss 302 heads trying to replicate the 300hp imported 4v
351 c australian QC motors.used in gt falcons.
I know someone who has a set of NASCAR 4 bolts main caps in Australia ---->PM if interested
I could be wrong, but I think Tim Meyer has been making brand new ones.
Tim has been shipping quite a few things to Australia it would be worthwhile contacting him, he may even have a set of used ones.
You do realize that main caps rarely interchange from block to block? They generally require the block to be line bored. They are not a universal bolt on part?
Your shop is going to need the right boring bar to do this procedure.
This often decreases the crankshaft / camshaft spacing very slightly but may require a special cam timing kit.
PM sent.
Ron
machine work down here.hes mr ford.
